(http://www.vatsim.net/sites/default/files/styles/large/public/EIDWOverload.png?itok=Wzjx-o9n)
14/11/2014 1700z-2200z Dublin, full service is promised and I'd imagine London Control is likely to pop on at the same time, so a good opportunity to fly from EIDW to any of our bases (EGLC, EGBB, EGPH or even EDDL).
By the way, it's now official airline procedure that if the designated callsign for your flight is already in use then you should use your Intercity pilot ID, but remove the leading digit. e.g. if you're crew/pilot ID is 1219 then you would connect as ICX219. I'll update the T&Cs to reflect this, shortly.
