Intercity Discussion Forums => ACARS => Topic started by: Robert Yunque on Mar 13, 2017 05:35
Title: ACARS and Pilotedge
Post by: Robert Yunque on Mar 13, 2017 05:35
Hello,
I have been working on my Dash8 all week, trying to get the controllers working right.  I found that little tool that is offered here and it worked beautifully. Made everything soooo easy.  I really appreciate being able to use that.
I tried to do my first Intercity flight, but all went wrong.  I haven't been flying on Vatsim, so I thought I would try it, but couldn't log in. I had re-activated my ID per the instructions, but something must still be wrong.
Then I tried the flight with the ACARS and I must have done something wrong, because it didn't record the flight.
Oh well, there is always another day. I enjoyed a nice flight from EGBB to EGPH, with a darn good landing on Rwy 24.
Lots of other mistakes though.  My flying with the Dash8 needs a lot more practice.
Thank you,
Bob
Title: Re: Tried my First Flight, but, well...no Joy
Post by: Chris Liu on Mar 13, 2017 10:45
Welcome aboard Bob!
Sorry to hear you had some teething issues, unfortunately I can't find any record of your flight to add it to your logbook (we can see incomplete flight records and complete them for you); it seems you may not have set ACARS recording, ensure you press the "Begin Flight" button and if ACARS doesn't make a tone during engine start then you can manually select "Off Blocks" and that will set it it going. There's a step-by-step guide at http://viaintercity.com/forums/acars/acars-user-manual/ (http://viaintercity.com/forums/acars/acars-user-manual/) if you need further assistance.
Don't worry too much about VATSIM to start with, trying to handle that on top of ACARS and the Q400 can be quite demanding!
Good luck and happy flying  :) If you're still having issues, let us know and we'll help as much as we can.
Post by: Chris Hulme on Mar 13, 2017 18:10
Welcome onboard, if you have the date, flight number and your departure and arrival times I can add this to your logbook manually.
If you need anymore help with ACARS just give us a shout on here and we will be more than happy to help!
Post by: Robert Yunque on Mar 14, 2017 03:44
Hello,
Thank you for your help.
I'll have a go at it again and see if I can get the ACARS right.  I put a ticket into Vatsim to find out why I can't log in, but haven't heard anything from them yet.
The flight was:
ICX0164  DH8D
13MAR2017\RELEASE 21:25UTC ARRIVAL 22:51UTC
ROUTING:
EGBB/33 - TNT1K TNT TIPIL N57 POL N601 ESKDO TWED3A - EGPH/24
I would appreciate you logging it in for me.  At least I'll have my first one count for something  ;)
Thank you,
Bob
Post by: Chris Hulme on Mar 14, 2017 09:17
Filed it for you
http://viaintercity.com/pirep.php?pirepid=4878 (http://viaintercity.com/pirep.php?pirepid=4878)
Post by: Robert Yunque on Mar 14, 2017 11:13
Thank you Chris.  I'm looking forward to trying it again very soon.
Bob
Post by: Benjamin Hall on Mar 15, 2017 18:02
Belated welcome to Intercity, Bob.
Out of interest do you use p3d or FSX?
Post by: Robert Yunque on Mar 15, 2017 21:35
Quote from: Benjamin Hall on Mar 15, 2017 18:02
Thank you Benjamin.  I appreciate that very much.
I use mostly P3Dv3, but I do have FSXSE installed and will use it for aircraft that are not designed for P3D.  I also use X-Plane 10 a lot.  I have X-Plane 11, but haven't used it that much because I have a hardware MCP that works with the IXEG 733, but only in X-Plane 10.
Its nice to make your acquaintance Benjamin.
I'm having a lot of fun learning the Majestic Dash 8 Pro. It is a really fun aircraft to fly that can get away from you pretty easily if you start getting distracted.
Post by: Benjamin Hall on Mar 16, 2017 18:01
The dash has punished me on many occasions when I have let my mind wander!
I have p3d v3.4 and sometimes find that I have to use manual on/off blocks unlike v2.5
Certainly is a fun machine and this is a small but very friendly VA
I'm sure you will enjoy it here!
Post by: Robert Yunque on Mar 17, 2017 02:27
Thank you Benjamin.  I believe I will too.
You guys don't do any Pilotedge flights, do you?
I fly on Pilotedge every now and then, but I want to start using Vatsim more too. (that's where this VA will work really nice).
I haven't had much chance to fly yet this week (darn).  I have been working a lot, which is a good thing.  May try again over the weekend.
My two favorite aircraft right now are the Dash and the FSL A320, and both of those are used in this VA for shorter flights, which really appeals to me a lot. I rarely have time for anything more than a couple of hours.
The A320 almost flies itself, but this Dash requires a little more attentiveness for sure, but it handles really nice.
Bob
Post by: Chris Liu on Mar 17, 2017 12:19
We're "network agnostic", you're welcome to use any online multiplayer network you wish. However, we have an official partnership with VATSIM and maintain ties with IVAO. You can fly on Pilotedge too, but I think they only cover West Coast USA?
Post by: Robert Yunque on Mar 18, 2017 00:23
Hello Chris,
Pilotedge has extended their coverage to most of the western United States, so there is a lot of city pair choices with many larger airports and different kinds of terrain.
Will the ACARS work still for Pilotedge?
I will also be flying Vatsim, if they can fix my login problem.  They still have not answered my support ticket.  I may have to make another one.
Thank you,
Bob
Post by: Chris Liu on Mar 18, 2017 08:58
ACARS communicates with flight sim via FSUIPC, the network you're flying on (or offline) makes no difference to what it sees.
Post by: Robert Yunque on Mar 18, 2017 14:25
Thank you Chris.  That's great.  :)
That will open up a lot of options.
Bob
Post by: Robert Yunque on May 29, 2017 07:55
Hello,
I just made my first ever flight on Vatsim. There wasn't many controllers, but I didn't do to bad with the one I had.  It was a real learning experience.
I was wondering how I can use the ACARS to do some flights on Pilotedge.  I see that it seems to only accept European routes.  Is there a way to put in a custom route and have it log the flight?
I would like to jump back and forth from Vatsim to Pilotedge with European and US flights.  Pilotedge has really expanded their coverage and handles practically the whole western U.S. now.
Thank you,
Bob
Title: Re: ACARS and Pilotedge
Post by: Gerald Plotts on May 29, 2017 15:16
Can't speak for management bit I don't think custom flights is an option. Intercity it 100% EU based, so don't think that will be a possibility.
Post by: Robert Yunque on May 29, 2017 16:58
QuoteCan't speak for management bit I don't think custom flights is an option. Intercity it 100% EU based, so don't think that will be a possibility.
I believe Chris indicated that there was a way to fly using Pilotedge, but I'm not sure now:
Quote from: Chris Liu on Mar 17, 2017 12:19
If not, I'll just fly on Pilotedge when I want to and Vatsim when I want them to be logged into Intercity.
Post by: Chris Hulme on May 29, 2017 21:54
Quote from: Robert Yunque on May 29, 2017 16:58
I believe Chris indicated that there was a way to fly using Pilotedge, but I'm not sure now.
http://viaintercity.com/forums/general-discussion/tried-my-first-flight-but-well-no-joy/new/?topicseen#new (http://viaintercity.com/forums/general-discussion/tried-my-first-flight-but-well-no-joy/new/?topicseen#new)
We only permit pilots to log hours with us flying along routes which are in our schedule (http://www.viaintercity.com/schedules.php) or ones which we have added as ad-hoc charters (these can be found under the Charter tab on ACARS).
At present we have no plans to expand into the US, so unfortunately you won't be able to log your hours on PilotEdge.
Just for reference, ACARS works with the sim itself, regardless of which network you are connected to so can be used on any online network or offline so long as your flying an Intercity flight.
Post by: Robert Yunque on May 30, 2017 03:19
Quote from: Chris Hulme on May 29, 2017 21:54
That's no problem Chris.   I don't need to have PilotEdge hours logged.  They log them over there.
While I got you, I was wondering, the Vatsim ATC wouldn't let me use "Intercity164" as my call sign, and made me use "Intex164".  Does that make sense to you?
Bob
Post by: Chris Hulme on May 30, 2017 09:04
We looked at many ICAO codes and chose ICX as its not been used by anyone since 1994. I tend to find if you call them up as Intercity and reply as Intercity they soon get the idea!
On VATSIM can use the flightplan remark OPR/INTERCITY to identify your airline and callsign to controllers, on IVAO use CS/INTERCITY in the same manner.
