Hi,
Deciding to be loyal, I planned to watch the England game. What better way to watch the match on the Ipad whilst cruising on a flight from Dusseldorf. Took ACARS a short while to kick in then off I went arriving in Kastrup EKCH to then have to watch a depressing last 15 minutes of football. Flight recorded. Job done.
Then when I checked the log Book I found I had booked and flown the reverse flight thus my log book shows EKCH to EDDL not the reverse route I had actually flown. No big deal for me as I did fly the leg. My question is should ACARS not give a warning or something if you are trying to start at the wrong airfield? Also on a slightly different note if you had to divert does ACARS in anyway allow for this?
Keith
Immediately noticed your problem.....watching football. Bunch of overpaid prima donna nancy boys. A decent game of rugby will cure all issues.
ACARS knows where you are but doesn't require you to be at the departure airport, maybe something I can add in! Although the route progress trip at the bottom would have been going backwards!
Ill amend your flight log for you though!
Thanks, Chris. As I said worked well anyway.
Ben, defo!!
Keith
