Intercity Discussion Forums => ACARS => Topic started by: Gert Visser on May 07, 2016 14:11
Title: acars / logbook problem? [Solved]
Post by: Gert Visser on May 07, 2016 14:11
Hi management,
My last flight from EGPH to LFQQ, ICX288, may 4th, was flown on IVAO. However, in my logbook it turns up as flown offline.
Do you know how this is possible and could you possibly change it to flown online Ivao?
Thanks!
Gert
Title: Re: acars / logbook problem?
Post by: Chris Hulme on May 07, 2016 17:54
Hi Gert
I've had a similar email this afternoon, currently out of the country but will have a look and fix on my return! Most probably a small mouse that's made it into the server and chewing wires!
Post by: Gert Visser on May 08, 2016 07:13
Hi Chris,
thanks! Have a nice journey back!
Gert
Post by: Chris Liu on May 09, 2016 15:30
Me and Chris went abroad at the same time (not together  ::) ), so apologies to anyone if we've seemed a little slow at responding.
Post by: Chris Hulme on May 09, 2016 18:20
I've updated your report....the investigation continues!
Title: Re: acars / logbook problem? [Solved]
Post by: Chris Hulme on May 10, 2016 10:01
Hi Gert
I think I've solved the issue...
A while back I moved the network selection button to the Flight Report tab on the Flight Logger screen. It seemed a more logical place to put it, and saved on transfering the data from screen to screen. Anyway I didnt see the need in releasing it as an update as so just left it and figured it would get picked up with the next release, and so it has been sent out with the new flight planner. So hopefully this should solve the issue as the drop down box has moved! If your still having problems let me know!
Chris
Post by: Gert Visser on May 10, 2016 18:38
Good day Chris,
Thanks!!
I observed the change in the acars. Since then I've flown another flight andonline on ivao registered ok!!
Gert
