(http://img.ie/ht687.png)
14/11/2014 1900z-2200z Dublin, Shannon and London will be all staffed I imagine, so it's a great opportunity to take the Q400 between EIDW and EGLC. Or you could take the A32S which serves Dublin from Düsseldorf.
By the way, it's now official airline procedure that if the designated callsign for your flight is already in use then you should use your Intercity pilot ID, but remove the leading digit. e.g. if you're crew/pilot ID is 1219 then you would connect as ICX219. I'll update the T&Cs to reflect this, shortly.
Tick!
Great fun and excellent ATC.
I still get sweaty palms after all this time :P
