Intercity Discussion Forums => ACARS => Topic started by: Scott Stephens on Jan 26, 2017 09:03
Title: Error Filing flight log [Solved]
Post by: Scott Stephens on Jan 26, 2017 09:03
Hi.
flight log 1701261812156 EGPH - EGPD...my first.
I know the Majestic can be difficult.  It recorded me off blocks, saw mid flight it said cruise.  Never recorded touch down or shutdown- no option of manually on the blocks.
What did I do wrong?
Scott
Title: Re: Error Filing flight log
Post by: Chris Hulme on Jan 26, 2017 09:16
Hi Scott
I can't see it on the incomplete flight list so not sure what's happened if you let me know the flight number and your off and on blocks times I will manually add it to your logbook. You have to manually select the option for the on off blocks buttons on the flight select screen if you require them.
Chris
Post by: Scott Stephens on Jan 26, 2017 10:08
Hi Chris it was ICX143 - didn't record the times sorry.  Its ok I will do it again.
Is it only manual off/on with Majestic - as I said it recorded the off and into cruise.
Scott
Post by: Chris Hulme on Jan 26, 2017 15:29
The option is only available if you select a Q400 flight. Normally when this happens we can recover it but it doesn't seem to have recorded it? The Majestic is a funny old bird and sometimes works and sometimes doesn't!
Post by: Chris Hulme on Jan 26, 2017 15:31
In fact, scrap that I've recovered it in our system. Will tidy up the position reports later for you!
