Intercity Discussion Forums => ACARS => Topic started by: Gerald Plotts on Nov 13, 2017 19:39
Title: Change request [Solved]
Post by: Gerald Plotts on Nov 13, 2017 19:39
Management team/developers extraordinaire, is it possible to get the "new flight" feature added back to acars? Since I regularly do multiple flights at the same setting, this was always useful (if only to me) so that I didn't have to exit the program and re-start.
Title: Re: Change request
Post by: Chris Hulme on Nov 13, 2017 19:43
Ermmm should still be there I don't recall removing it. Will check tomorrow when I get chance
Post by: Chris Hulme on Nov 15, 2017 10:23
I've re added it in, appears the line of code to make the button appear got removed, probably accidentally whilst I've been messing around with something else!
Title: Re: Change request [Solved]
Post by: Gerald Plotts on Nov 15, 2017 19:50
Thanks Chris for the fix. Much appreciated!
Post by: Chris Liu on Nov 15, 2017 23:44
Chris is dangerous with a keyboard sometimes!  ;D
Post by: Gerald Plotts on Nov 22, 2017 13:28
I hate to keep at this, but with the last update you did (I know I took my time reporting), the "NEW FLIGHT" button is still not there. Showing 2017115 for the version number. Tried this on my windows 10 and windows 7 machines, deleted all with re-install and no joy. Again, not a big deal, as I just exit acars and re-start it. Appreciate the great work you guys do. Thanks
Post by: Chris Hulme on Nov 23, 2017 17:22
I've re-uploaded and tested and its defiantly there now!
(https://i.snag.gy/hH4s6n.jpg)
Post by: Chris Liu on Nov 23, 2017 20:42
Quote from: Chris Liu on Nov 15, 2017 23:44
Quote from: Chris Hulme on Nov 23, 2017 17:22
See what I mean  ::)
Post by: Gerald Plotts on Nov 24, 2017 13:46
Chris, just finished EDDL-LEBL, and upon termination of the flight, that "NEW FIGHT" button is present. Thanks for the fix, and speedy response.
Post by: Chris Hulme on Nov 24, 2017 19:57
It actually appears when you press send report so just make sure it's sent before you press new flight or you'll loose your flight data!
