Intercity Discussion Forums => ACARS => Topic started by: Chris Hulme on Dec 06, 2015 12:54
Hi EveryoneI have released an update for ACARS today that should hopefully solve the issues with the updater that people seem to have been having recently. If you are having a problem with the updater then please re download ACARS here (http://viaintercity.com/downloads/acarsinstall.zip). If not then update as normal. The updater should now request admin rights if your UAC is set for it to do so.Quote from: Chris Hulme on Dec 06, 2015 12:52
Hi Everyone
Please read the following before posting any ACARS problems in this forum.
If you experience any issues whilst running the updater then please try the following:
1 - Temporarily disable your Anti Virus and run ACARS to automatically update.
2 - Go to C:\Program Files\Intercity ACARS\ (Or your install path) and right click the "update.exe" and choose "Run as Administrator". The updater should then run downloaded the latest version of ACARS and launch it.
3 - If the above doesn't work then uninstall ACARS and be sure to remove the install directory (For example C:\Program Files\Intercity ACARS\) Once you have done this, re download ACARS here and re install.This will give you the latest version and also ensure that the updater has the admin rights it needs.
If the above doesn't work or your problem is with ACARS itself then please create a new topic and include the following information:
If Updater Issue
Operating System:
Screenshot(s) of the errors:
If ACARS Issue
Operating System:
Simulator (e.g FSX, P3D):
Aircraft being flown:
Model of aircraft (e.g Majestic, PMDG):
Phase of flight:
Did the sim crash?:
Did the PC crash:
Did you resume your flight:
Any other relevant information:
