My ACARS was stuck on departing after I landed.
ICX662 EDDL-EDDB
Could you provide some more information? Possibly a screenshot of the ACARS? Are you using FS2Crew by any chance?
Unfortunately i quit the flight. Yes I'm using fs2crew.
The issue lies with FS2Crew, and a work around is covered in this news topic (http://viaintercity.com/forums/news/q400-off-blocks-not-detected/)
Quote from: Chris Liu on Mar 26, 2016 01:26If you do not hear the off-blocks sound after starting the first engine(with the condition lever in start & feather) then when you need max condition, move the levers using your mouse. This will trigger off blocks.
I have also recovered your report, although the speed and altitude map seems to be a bit off!
http://www.viaintercity.com/pirep.php?pirepid=4094 (http://www.viaintercity.com/pirep.php?pirepid=4094)
